Amps are a bit more work than pedals - for one thing lead dress (the way you place the wiring, the way you ground the amp) is critical to getting an amp which doesn't oscillate, hum or make strange noises. But it's not impossible. The first amp I ever built was a 5E3 and it sounded pretty good. Now when I make a 5E3 it sounds a lot better though because I learnt from that first one and every one since.
I would probably recommend a 5E3 as a first build. I built a couple of tweed Champs and never really bonded with them. The main thing with a 5E3 is learning how to bias it properly - it makes a huge difference. And it's a bit of a head scratcher at first but you have this place to help. Most of the time people build a cathode biased amp according to the 1959 schematic and if you do it will most likely sound like mush when you turn the volume past 3. Wall voltages are higher these days than in 1959 so the B+ will be higher. I would highly recommend using a slightly lower B+ PT from MM to help make your amps sound more authentic. But if you don't want to you can still get a great sounding 5E3 by using a higher value bias resistor. You want around 100% plate dissipation for a cathode biased amp. It's not that hard to get dialled in with a DMM and a few values in 5-10W resistors.
One of the best sounding amps I have built is the 5F11 Tweed Vibrolux, and it's not much harder than a 5E3. The amp I play most right now is a Brown Deluxe 6G3. Fabulous tremolo and a big fat sound. I like it way more than any BF Fender I've played. Takes my pedals well.
I had been waiting for rosamp.com to open up shop again so I could grab an SLO-30 kit but I didn't know Ceriatone had amp kits as well. They have a pretty killer selection of kits with various options too. I might buy a kit from them and then get a SLO-30 whenever rosamp is back in business haha. mojotone has some cool kits too.
1 Watt, 2 channels. Supposed to be a 5E3 (clean) and a JCM800 (dirt). I have not dug into the schematic enough yet. But the demos seem like it would be perfect for me.
Sounds like fun! But remember part of the plexi sound is the speakers breaking up at high volume.
So many different speakers too. A million variables....
I was playing one of my 5e3's a few nights ago with a newly purchased FANE M65, hand made in England. It is amazing. For the first time in my 57 years of playing guitar I felt like I had finally captured the Gilmour sound as I was strumming the chords to shine on your crazy diamond.
If I strummed lightly it was clean as a whistle, and when I strummed really hard it was screaming with breakup.
Needless to say I was in tone heaven on Friday night, lol
This was one of the amps my "business partner" had possession of when he got sick and eventually passed away. Took me a decade+ to get them back and they were mouse pissed and rusted. Gaaa. This is the first I've restored and put back into service with Russian PIO caps. The M65 is in the "Soundtown" cab which is a really incredible deal for an EMPTY cab. Why they would say an empty cab is 65 watts is kinda weird.
Ooooweee I’m glad you pointed that out. I definitely would have missed that one. Strongly considering the Ceriatone FAS 50. I just moved apartments… so I’m going to wait a few weeks until I have everything unpacked and organized then I am 99% sure I will go with the Ceriatone
I still wanna build an amp at some point, but I’m thinking the next thing I do is take my Vox AC15TB to be serviced/resurrected. Clean it up, new caps, etc. Don’t wanna try it myself because I’ve never worked on an amp, and I don’t wanna eff up something that’s almost vintage.
So many options for kits in this thread! Still will probably go with a 5e3 or 5f11 as a first build.
I love to build amps. I have so many in the pipeline right now it's kinda funny. Do I need them? Hell no. I am going to be building a Marshall Superlead 100w 2203. Eddie Van Halen's amp, if you use the 50k pot for the mid instead of the 25k, and run at 100v (I think, he did use a variac)
Have all the components, a LARGE tote full of resistors, the iron and chassis, the speakers, and the speaker cab. I make the circuit boards myself, from scratch including sawing the G10 epoxy board with wet tile saw ('cuz otherwise the toxic smell is horrendous). And I have well over a thousand original phillips Mustard caps which were the original caps used in Marshall, Vox, Hiwatt, etc.
20 years ago, the economy in Greece burped and people were scrambling to put food on the table. I helped them put food on the table, and ended up with freaking boat load of caps, thanks to eBay auctions.
I have built many 50w, but have never done a 100w. And I'm 68, so times a wasting!
My layout so I can make the hole drilling template for the circuit board
20 years ago, the economy in Greece burped and people where scrambling to put food on the table. I helped them put food on the table, and ended up with freaking boat load of caps, thanks to eBay auctions.
Not gonna lie, I watched Pete Thorn's video on the Mick Mars'/Richard Fortus' Jose modded Super Lead. I was inspired. I need to watch it again, but I think that one is just the extra gain stage in front and a pre-phase inverter master volume.
I also still have my amp in a 50cal ammo can idea that I think needs to be something pre-CBS, probably AB763.
Anyone know how a JMI spec Vox AC4 would be as a first tube amp build? don’t think there are any kits out there for it, but idk if that should be much of a deterrent.
It shouldn't be too much harder than a 5F1. Check this out to see what it would involve. Here is mine (I made my own layout, didn't see Steve's until after I made mine):
It shouldn't be too much harder than a 5F1. Check this out to see what it would involve. Here is mine (I made my own layout, didn't see Steve's until after I made mine): View attachment 81352View attachment 81353
Thanks for the link! Definitely doesn’t look too tough. I guess I just need to start pricing stuff out.
Nice looking build! Is that a Weber AlNiCo blue pup for the speaker?
My first tube amp was a peavey delta blues with 1x15. I really liked the 15 in it and that’s been kicking around in my head. So I thought 5e3 and a 15.
BYOC didn’t have any 5e3 chassis’s left, but they did have 5f1. And they had a 15w transformer and instructions for a 6L6 version.
I got the heavy stuff. 5f1 1x15 rawcab is on the way. Just need small parts and tubes.
