SOLVED Deflector - no effect..
Knotty Pine
Just built up a deflector and it passes signal but there is no effect, super bummed..
you need to get the effect out of the box so you can share a picture of the other side, including under the pots. and then see if it works when it is out of the box.
if you are not getting anything when the effect is not bypassed, look at some other posts in the troubleshooting forum for some ideas about where to start.
