I don’t think parallel diodes facing the same way actually do anything different than just having one… so the one on the left would be symmetrical hard clipping with an extra redundant diode, and the one on the right would be assymetric hard clipping. (Forward voltage of the two series diodes add).
The one on the left, if the two diodes with anode to ground had different forward voltages, then only the one with the lower forward voltage would clip.
And the one on the right with two diodes in series, those two will have their forward voltages sum giving less clipping and more volume than the single anti-parallel diode they're paired with.
I am wondering what the effects are of putting diodes in parallel or putting them in series. (like current capabilities, voltage capabilities etc.) Let's say I have a datasheet of a diode. What
I think on the example on the left, the signal will only see one diode in the pair that are oriented in the same direction. I'm guessing the one with the lower Vf?
Thanks, guys. Was wondering how best to put this on a breadboard project I'm working on right now.
Edit: For the example on the left, if I have a mixture of diodes would that change anything? I understand now that one would be redundant if they were identical diodes. What if one was a red LED and the other green?
I used to think that was true, but it's actually not quite that simple. Vf is a function of current and some diodes have rather large resistance. If you put a silicon and germanium diode in parallel, the Ge diode will conduct most of the current at low currents, but as you raise the current, the Ge diode's Vf can exceed the Si diode's Vf. At that point, the Si diode conducts the lion's share of the current. The plot below shows some measured data comparing the D2V germanium diode with the 1N914 silicon diode. Below 4.7mA, the D2V conducts most of the current. Above 4.7mA, the 1N914 conducts most of the current. When we reverse-bias the Ge/Si pair, the Ge diode will conduct essentially all of the reverse current because Ge diodes are very leaky.
I've always been curious about a ge and si diodes in series. It'd be great to be able to raise the Vf threshold and retain the characteristics of germanium clipping without requiring two or three in series in order to do so.
