SOLVED Double Jeopardy: high pitched whine (isolated power supply)
slowpogo
I built the Double Jeopardy and it works great, except there's a faint high-pitched noise when it turns on. The noise gets louder as I raise the gain knob. I have a Onespot CS12 power supply and the DJ has its own output, not daisy chained. The whine is there even if it's just guitar>Double Jeopardy>amp so I think the pedal itself is causing this.
I didn't notice it right away because if I run the boost into a dirt pedal, the high pitched whine goes away. But if I want to boost a clean signal it's obvious.
any idea what might cause this high pitched sound? Is it worth trying different transistors or diodes?
I tried a different TC1044, and also added some extra insulation between the pot and the board. It's a double-decker pot and my regular plastic pot covers don't fit well, even after cutting a notch, so I had just put some electrical tape on the back. I added a few more layers.
The whine is gone! I guess it was either a bad IC, or not enough insulation against the pot causing problems. Thanks again, not sure why I didn't even think about the charge pump.
Great, glad to hear that it worked for you. Please mark it as solved!
