Duck Box
bhcarpenter
Ridiculously fun, and an easy build to boot. This would be a great first project.
Thanks all who recommended it in my “pedals for bass” thread.
The artwork is so simple yet perfect.
This pedal is on my list but I can't find the 4558s. Definitely need it for bass, the thread linked above also led me to buy this PCB.
Aren't 4558s the most commonly available dual opamp?
I have no idea, just a noob. But I do know that I can't find any NJM4558s and I don't have the knowledge to know if any other IC with 4558 in the name is a substitute.
For example, are the TC1044SCPA and MAX1044 equivalent?
Just make sure the 4558 you order is a DIP:
(unless you have a build that requires a SIP):
images
Chip-sniffers will opine there is a difference between an older JRC and NJM or other newer variants, but …
I suggest — SOCKET your IC, buy some chips (TL072, TL082, 4558, 4559?, Burr Brown, etc) and see what works best for you & your Duck Box, trust your own ears — if you can hear a difference, is the pricey Burr Brown worth the added expense?
For charge pumps, I have heard of problems with the max1044 so I stick with TC1044SCPA.
