jwyles90
Hey all!
I just finished putting together this Duo-Phase, and everything is working as it should except I'm getting a fair amount LFO ticking from it. It happens the most prominently when the left side (looking at the front of the enclosure) is engaged, or when it's bypassed altogether. If I've got the right side engaged, or both at the same time, it's virtually nonexistent.
I went through and looked at all the other troubleshooting threads with this similar issue, and it seems that moving the wires around can sometimes help. I gave that a shot, and even tried using some shielded wire on the in/out jacks, and it didn't really seem to mitigate the issue all that much. I've also never used shielded wire, so there could very well be something to it that I'm unaware I need to do to make it function properly.
I suspect that I might also be getting some noise from the switched jack input wire, since it impacted the ticking a bit when I moved it around while it was plugged into my amp. I'm going to try rerouting all the wires that run the length of the enclosure to go underneath the PCB when I get home from work today, but in the meantime, I was wondering if there was anything else I could look for or try to do that maybe I'm not spotting or thinking of. Thanks in advance for all your help!!
![IMG_3983.jpg IMG_3983.jpg](https://pedalpcb-forum.nyc3.digitaloceanspaces.com/data/attachments/73/73687-4603a7dd0b8ad8265f162f3ffaa95d7b.jpg?hash=RgOn3QuK2C)
