droneshotfpv
I MAY know the answer to this already, but wanted to ask the more qualified peeps than myself. I just built my DUOCAST, sounds amazing in 9v mode.
I made sure ALL my caps (as I usually use anyway) were rated 50v+ before using them, aside of one "special" order one I needed to order to complete the build, which was the sole 330uf cap, and it's 35v, which should be plenty.
Anyway, plugging along, this thing, as I said, sound marvelous until I switch to the 27v mode.. When engaged, it makes sound, but quickly fades out like a fuzz being gated to brink of extinction. Literally goes quiet, but sounds as if, and this is the BEST way to describe it, the sound is what I could compare to a capacitor being full of energy, and then depleted as the voltage leaves the unit...
Fiddling with the switch, I eventually got it to come on, and stay on in that mode (27v) but switching back to 9v mode, it works perfect EVERY time, and then back to 27v, same thing all over again.
I assume I could POSSIBLY have a bad switch, which is gonna suck to swap, but that's an easy place to start, unless anyone could think of different?
Another weird thing I noticed, I am OCD when it comes to checking values / voltages before firing up any new pedal. I put my meter on the this one in 9v mode, checked the voltage at the switch (among other areas) and got 9v on the 9v switch side, but when flipping to 27v and testing those prongs, it started at 37v, and drained down slowly in the teens... I flipped back to 9v, measured, solid, 27v, trickled back down from high 30's again...
So, does this prove the switch is a POS and I need to yank it and try a new one?
Thanks in advance my pedal crazy brothers and sisters!
***EDIT***
Correction, The "drain" I noticed was not when switching the switch TO the 27v side, but rather I tested again and noticed it was when switch to the 9v side... I dunno, this has me baffled lol Help me Obe One, you're my only hope
***EDIT***
