Hey @vigilante398 did you ever make these available? I don't see them on your website. TIA!I completely forgot to release this. Whoops. The DIY through-hole boards have been verified and they work and sound great, they fit the exact same enclosure as the Space Heater. There are a couple places where I may recommend alternate components as there are a couple odd values (82k and 2.87k resistor) that aren't that important and can be substituted. But if people want to try it out I can get it put together.
Oh right, nope haven't done that yet. I'll see if I can get the build doc put together in the next couple days (I have a template so it's not hard, just need to plug it in) then get them posted.Hey @vigilante398 did you ever make these available? I don't see them on your website. TIA!
Definitely put me down for one. I'm stoked about this!Oh right, nope haven't done that yet. I'll see if I can get the build doc put together in the next couple days (I have a template so it's not hard, just need to plug it in) then get them posted.
Alright, finally got the build doc put together, you can take a look at it here.
A couple notes about the build:
So with all that in mind, I'll say that it's about as easy of a build as Space Heater, it's a fairly simple circuit and is in the same form factor and will go in the same enclosure. The PCB isn't live on the website yet, but I'll get it up this afternoon and let everyone here know.
- There are a couple weird resistor values (2k87 and 85k) that are not critical and can be replaced with the closest readily available value (2k7 and 82k) without really affecting the sound.
- YOU HAVE TO USE AN EF86. 12A*7 family tubes WILL NOT WORK in this build. It can be an actual branded EF86 or a Soviet 6Ж32П (6J32P), but it has to be a single pentode, not a dual triode.
- Since this is a single pentode stage it will not overdrive by itself, this is just a clean tube stage that you can either run by itself as a clean preamp, put in front of an amp to use as a clean boost, or run something else in front of it to push the pentode into overdrive.
- I put a link to Antique Electronic Supply for the EF86 tube, but you can generally get them MUCH cheaper on eBay. "Winged C" and Svetlana are common brands for the 6Ж32П, but there are plenty of NOS EF86 available for cheaper than you can get a modern production EF86.
- And something to keep in mind about EF86 in general, they are far more likely than 12AX7 to be microphonic, so it's not a bad idea to pick up some silicone damper rings to throw on your tube to help tame it. Alternatively you can do what I did and buy a huge batch of tubes then sort them for the lowest microphonics
They weren't a minute ago, but they are now.Are these in your store now?
 drive.google.com
					drive.google.com
				 drive.google.com
					drive.google.com
				I don't have any personal experience dealing with the 6267, but looking at the datasheet it certainly looks equivalent. The only place I'm seeing mention of less microphonics is from TAD, but they list their tube as "EF86/6267" and I've personally bought TAD EF86 and had the same microphonics problems with those as with the Winged C 6J32P. The only brand I've found that actually seems to have less microphonics (again in my limited experience) was JJ/Tesla.from what I've read it seems like the 6267 should be less microphonic than the EF86 but otherwise the same- Any thoughts on this?
Looks like an interesting idea, I've never tried it though. May be worth looking at. I've had good luck with JJ EF86 for low microphonics, but they are generally a bit more expensive than 12AU7.I absolutely love the EF86 Vox/Matchless hybrid amp I built. Sounds amazing on its own and takes pedals like a champ.
An alternative to the EF86 I've been eyeing is a 12AU7 wired as a cascode. I'm a devotee of Merlin's books and he's backed that option as sounding almost identical with none of the drawbacks of the EF86 (cost, microphonic, etc.).
It's going to have the new tube mounting setup, but it's also going to be a different circuit. The current plan (which has already been designed and prototype PCBs have been ordered) is to do a preamp based on the EF86 channel of the Matchless DC30, my favorite channel of my favorite amp ever.I’m not sure if you’re ready for the reveal, but is the replacement going to expand on the echo foxtrot features or is it just changing how the tube is mounted?
