Fuzzonaut
This one s based on the Dunwich Olde Dirty Bass, which itself is inspired by the OCD. It has a bi-polar charge pump, a 3-band EQ, LED and Mosfet clipping and the "Cut" switch determines how much bass there is early in the circuit.
As Dr Doom himself put it: "The circuit is derived from a OCD but like the Volt Thrower scraps most of the circuit after the clipping diodes and uses the same Bass and Treble EQ as in the Volt Thrower. However, an added Mid Boost control was included to increase the flexiblity of the EQ. Also like the Volt Thrower, the pedal was conceived to be a bass-friendly design."
In short: Great, versatile bass OD. Highly recommended.
