Electrovibe Expression Pedal Mod
How would I go about adding an expression in to the Electrovibe and how would it be wired?
I can write up an explanation for you tomorrow if you’d like, but be warned— it requires a dual expression pedal and two expression jacks, which there isn’t room for in a normal build; you’d need to build it in a bigger enclosure, like a 1590XX, which might not be appealing to you. If that isn’t up your alley, you might prefer building the madbean harbinger two, which is built into a Wah shell, but isn’t exactly the same as the Electrovibe.
Shaft or collar?
Sorry, I'm not getting this. How the hell do you change out shafts on pots? I've swapped the resistance-discs in pots, but the shaft — ie the bit that a knob would normally attach to, gets a pinion, ie tined-gear / splined-cog / toothed-collar, no?
"...He's a complicated man
But no one understands him but his woman...
Well why didn't ya say so in the first place? 😸
Thanks Big Monk. Sometimes I just need a good hit on the head to get the right perspective.
alright so I’m still in the considering phase here. But I am thinking of not having the second speed pot and just setting up the second speed setting as an expression setting.
So first I get that I need 2 jacks a dual expression bigger enclosure blah blah. Just not sure which pot lug spot goes where on the trs jack. 1-t, 2-s, 3-r or? Would it be different for speed 2.1 vs speed 2.2
Thanks.
