For those who want 15 volts regulated try the LDO regI'll try to get it posted today or tomorrow.
I used L78L15 because that's what other comparable vibes use. Chuck has mentioned (and is correct) that the 15V supply isn't quite high enough for the 15V regulator to actually do it's job and suggested as 12V regulator instead. (L78L12 would work fine)
LM2937-15
It only needs 15.6 volts input to regulate. Mouser has them.
I haven't seen the schematic but will a 7660 or 1044 charge pump work with the current demands of this board or will it need the LT1054 charge pump?
