SOLVED Episode Boost biasing
EGRENIER
I just completed the episode boost. Now I need to bias it with the trim pot. I’m not sure what I’m supposed to look for in terms of value or even sound.
I assume I’m biasing Q1 (2n5457) based on the trim pot location. I read in some Other thread that I should aim for half of the voltage. So when the pedal is on 9V should I read 4.5V on the collector ?
Right now full, open gives me 9.22V and if I turn the trim pot CW I can drop it to 7V. I checked and I have the right trim pot 50K.
So when facing the flat side starting from the left I read:
with pot CCW all the way
9.22V, 229.5 mV and 0
with pot CW all the way
7V, 218 mV and 0
Any suggestion ?
I can't claim it was designed this way. More likely, the jfet is out of spec and is not biasing in the range.
If you're happy with the way the pedal sounds as is, you probably don't need to be too concerned about how it biased. If you're experience some unpleasant distortion or compression, then you can either try to find another jfet, or try a 100K trimmer and see if that helps.
I have 2 more JFET, so I can could try swapping them and see if that change anything, however I understood that what I measure is what I feed the JFET no ?
Yes, but what you feed to the jfet will be impacted by the jfet itself (and if it weren't, there'd be no reason for a trimmer).
I meant where are you measuring the source voltage?
1645465008791-png.23303
OK let me recap this, the only measurement I've taken are on the JFET pins:
So with the pedal set to 9V and when facing the flat side starting from the left I read.
With pot CCW all the way:
Drain: 9.22V
Source: 229.5 mV
Gate: 0V
with pot CW all the way:
Drain: 7V
Source: 218 mV
Gate: 0V
The source is VCC before the trimpot no ? So I didn't check that but I would on the 9V/18V switch if I need to...
If you tell me what you need from the board, I can pull the value quickly...
Your JFET is too cold (Idss & Vp too low). All too common to find those on eBay. Probably the leftovers from someone else cherry-picking the "good" ones. Take solace in the knowledge that your cold 2N5457s will be useful as subs for J201 in some pedals. Ideally, you should find a hotter JFET. Doesn't have to be 2N5457. Did you solder the transistors into the sockets? What' the point of using sockets if you're gonna solder them in? Your other alternative is to reduce R4 (try 2.2K) or change the BIAS pot to 100K.
A brief JFET lesson:
JFETs run in constant-current mode, which means once you've picked a device and a source resistor, the DC drain current is constant and does not change if Vcc or the drain resistor (\trimmer) are changed. The only exception is if the JFET saturates (Vd = Vs) and we don't want that. I bring this up because you can dial-in the drain voltage to 50% or (65% or whatever) of Vcc at 9V and if you change to 18V you won't be anywhere near 50% of Vcc anymore. In my mind, this means that there is no "magic" bias setting, only the one that sounds acceptable to you at both 9V or 18V.
Oh boy, now I look like a fool :D
Yes I did tack the middle pin to the socket. I used socket to easily swap the transistor and usually put a tack once I confirm the pedal works. I'm always afraid that the transistor may come loss if the pedal is tossed around. I can probably swap the JFET easily, I have two more, hopefully not also "too cold"...
If the JFET is working fine, what value should I read of the drain pin ?
You should be able to get 1/2 Vcc without running the trimmer to the end stop. Doesn't mean that's the idea value, but it's a good starting point.
If you have a breadboard, you can pre-test your transistors there, then solder them in and you don't have to mess with sockets.
Don't have a breadboard :(
But ok, that 1/2Vcc is what I would measure on the drain pin correct ?
I will try to swap the JFET and see if one works better...
If you're going to build with JFETs or germanium, a breadboard is highly recommended. This is all you need to get started:
https://www.amazon.com/gp/product/B07LFD4LT6
FYI, I just tried four random in-spec 2N5457s with Vcc = 9.08V, R4 = 4.7K and Rd (trimmer) = 47K. The Vd readings were between 6.63V and 6.93V. These parts were all at the lower end of the spec range. For S&G I also tried PF5102, J112 & 2SK193. They could all be dialed-in to 4.5V with the trimmer somewhere in the middle. Electronic Goldmine sells 2SK193 4ea for $2.
Mmmmmmmmmmmmaaaaaaaaaaaaaaybeeeeeeeeeeeeeeee.
Test 'em all for Vp & Idss when you get 'em. If any are out of spec, then you can decided whether to keep them or return for refund. The pic in the advert has all identification obliterated; that's not encouraging. Read the first review, they do look fake. Do ya feel lucky?
Let me see what I have.
I believe I have some leftovers from my Aion Ares build. Are you in the US?
Nah, I'm in Canada... I appreciate the offer tho...
Tayda has some J112 in stock, I guess it's time to put, yet, another order in... DHL kills me on shipping but if I load up on stuff it make it worth it...
Anyway, first thing first, let's see what the other 2 are like...
Appreciate all your help, I'll keep you posted.
Get on EG's mailing list. They put stuff on sale every week. It's surplus, so stuff constantly comes and goes. They have some generic Vactrol-type devices; a good deal when they're on sale. You have to test 'em 'cause there are usually a few duds. At 12 for $3, I don't mind having to toss a few out.
J112s have a large spec range for Idss & Vp, so be prepared to test & sort them. You might want to get some 2N5458s from Tayda as well. They are like 2N5457s, only hotter.
Will do...
I got also those on the Tayda order:
You had recommended the 6 packs, do I need 6 ? I guess you'll tell me that depends how big the project I will breadboard... At 2$ each, I don't mind having more than less.
In terms of tools/accessories/testing goes anything you'd recommend to get from Tayda ? So far, I'm loading up on knobs, power jacks and leds...
Those are pretty small and you only need one or two. It is the least expensive option and you can give the extras to your pedal-building friends.
I have been using mostly ZY-204 solderless breadboards. They are featured in most of the breadboard pix I've posted. Plenty of room to build anything on this site. I get 'em on eBay and I buy from the seller with the best price + shipping at the time.
1% 1/8W resistors, WIMA film caps, tantalum caps, opamps (the usual suspects) & pots. You can never have enough of any of those.
Yeah, I'm pretty much loaded for those... Obviously not all the values, but normally when I need one I buy 20...
I wish Tayda had Transistor testers or other tools of that nature... But testing on breadboard will be a good learning experience.
