SOLVED First vero build - circuit works but output is barely audible.
zakco
My first Vero build. It’s the Mind Bender as per this layout:
The only modification is the trimpot is wired off-board to a regular pot
Voltages at all transistors are good, all controls function as expected but the output is barely audible - probably 30db quieter than it should be, but I can clearly hear that other than the output level, the volume, attack and bias pots are working. The gigantic GT404s make it difficult to see the top layout, but I've taken photos from a few angles, so hopefully everything is visible.
Any help would be appreciated, thanks!
Can you bias it out with the trimmer?
was it this gated when you breadboarded the circuit? (with the exact same transistors, in the same positions, i presume).
This vero layout doesn't have a trimmer on Q1, so I have removed the transistors and rebuilt the circuit on a breadboard using this schematic: https://generalguitargadgets.com/pdf/ggg_tb_m2p_sc_ng.pdf
Q3c biased to almost exactly 8v with a fixed 15k resistor and with a trimmer on Q1c, I balanced Q1 to 8v with a fixed 8k2 resistor and now the circuit sounds glorious. A nice wide range on the Attack pot with no unwanted gating. It sounds so good, I might just skip the bias pot altogether when I put it back on vero. Fingers crossed I don't screw it up again!
EDIT: I messed around a bit more with the bias and I actually prefer the sound with Q1c and Q3c both at 8.4v . It sounds pretty much the same at higher gain settings, but it's sweeter and more controlled when the Attack control is turned way down.
EDIT: Yes, you are absolutely right. I read the outline of the trimmer as a connection. I re-soldered the output cap to the correct junction at it works! Well done...thank you! And boy do I feel dumb...sheesh.
How can you feel dumb after learning something? You should feel anti-dumb now. You are stronger as a result of your new knowledge…
I put it in an enclosure and everything works well, except I've noticed that the LED brightness pulses a little bit. Not by much and not constantly, but it's definitely noticeable if you're paying attention. I can't detect anything audible and the voltage remains steady at both the +9v rail as well as the transistor collectors. I'm using the PPCB breakout board with the LED connections, but no brightness control. Any ideas why this might be happening?
This process has made me really appreciate the premade PCBs I've used up to now with their conveniently located power, ground and i/o pads! I've always used Tayda's drill service, so this was my first time drilling metal and it turned out pretty good - only one slight oval that is covered by the jack washer.
