Footswitch and schematics
DDad
I see on the schematics I chose at random that the footswitch is labeled SW or SWGD and shows two circles, in the part of the circuit that takes the LED to ground. So if the switch is on, the LED lights up. But I am not seeing any other pole of the footswitch on the schematics, just the LED pole. Shouldn't the other pole be disconnecting the input? It looks to me like the whole pedal is turned on (Vcc and Input) whether the footswitch is on or off. Here is an example - Muroidea
That isn't shown on the schematic...please take a look. That is what I was saying - no pole doing the switching of the input, just the LED to ground.
The bypass switching typically isn't part of the schematic when it isn't part of the circuit / PCB.
You see the SW and GND pad because they are used to illuminate the LED, which is on the PCB itself. The LED, current limiting resistor, and SW/GND pads are physical parts of the circuit.
A builder might choose a footswitch, a relay, some sort of electrical or optical bypass, or to hard-wire the circuit always-on. The schematic shows the circuit, how you activate/bypass/power it is entirely up to you.
The wiring diagram on the other hand, typically does show a standard straightforward true-bypass scheme using a 3PDT footswitch.
Just for the sake of conversation, if the footswitch was included on the schematic this is pretty much what it would look like:
(Muroidea, since you specifically named that project)
Anything outside of the shaded area is not a part of the PCB.
