fuzz face
oliverstromberg
Would be sweet with just a real simpel vintage style NPN silicon fuzz face with 3pdt footswitch a 9vdc adaptor and Led, or maybe just help with how to draw up the schematics with all the mounting holes
Thanks!
Thanks!
You could use the Sunflower PCB to achieve that (if you search the forum you'll find at least a couple threads with more information on that).
Thanks!
If you short past the “clean” and “sun” controls, the Sandspur is exactly that
EDIT forgot, the original FF circuit also uses an A500K for volume, so you’d short past the two potentiometers and use an A500K and you’re good to go!
