ChrsGuit
Hey guys... This has to do with a pedal I've owned for quite some time (since new)...
I have a Matthew's Effects Astronomer... It's a hall-shimmer Reverb..Been on my board since new, probably 2016 or so...
A couple years ago it was randomly acting up... the effect would engage but severely dropped the volume.
This was never a problem before, having used this pedal countless times in the studio and live...
Used to, I could cycle the switch several times and the issue would go away... I eventually pulled it off my board in favor of other things...
I just dug it back out tonight and the same issue is going on, except it wont clear up with several cycles of the switch...
There is an audible "pop" when engaging the pedal.
Mine is an early one (serial 68) back when the company was using cheapo clunky switches (now they use no-click, zero resistance switches)
Just curious if a faulty switch is the likely culprit. Jacks are tight, and I'd never even opened up the pedal til now.... I can't see anything blatant like a loose/bad solder joint...
Any thoughts where I should look first?
