mkstewartesq
Hello:
About to build the General Tso, which will be my first effect with buffered bypass. Is it possible to use the buffered bypass breakout board with this PCB? If so, could anyone give me pointers on how the breakout board should be wired to the PCB? I have attached pictures of the wiring per the build doc and the breakout board if that helps.
I don’t have a problem manually wiring the 3PDT per the build documents if I need to - but I accidentally purchased some buffered breakout boards a while back that are just going unused so I thought I would use one of them here if possible. However, obviously the wiring in general is new to me, especially not knowing what to do with that “mute“ pad on the PCB since there isn’t a corresponding labeled pad on the breakout board.
Thanks in advance,
Mike
Thanks in advance,
Mike
