fancypete
I'm almost done boxing up a General Tso. While testing components I noticed that the green LEDs I have are very dim. Worried that the cheap green LEDs weren't up to the job I checked the data sheets. I bought the LDRs from Tayda (KE10720), which are a little off spec from what the build docs call for. I googled the data sheet for the LDRs and it shows peak spectral response from about 600-650nm. 650nm is squarely in red territory. So, in theory, wouldn't a red LED give a better response from the LDR? The GL5516 LDR in the build docs peaks at 550nm, so I figured it might be better to match the LED to the LDR I'm using.
All this to say I'm hoping the pedal works correctly with red LEDs. Cuz that's what I'm using. I'll report back with results but I'm curious to know what anyone thinks. Am I overthinking this? I'm sure someone has more experience with this than me!
