bechbox Member Yesterday at 4:15 PM #1 I'm building a General Tso compressor, but get no sound in bypass or when engaged. I inspected all solderings visually and did a test with an audio probe. I get sound up until one leg of Q1, but nothing in either legs of R6, D3 and D4 Anyone know what's up? Here's the schematic:
Synchrony Pedalworks Well-known member Yesterday at 6:09 PM #2 With no sound for bypass or engaged, you need to check your off board wiring, either at the jacks or footswitch. Upvote 0 Downvote
Robert Reverse Engineer Yesterday at 6:32 PM #3 Synchrony Pedalworks said: With no sound for bypass or engaged, you need to check your off board wiring, either at the jacks or footswitch. Click to expand... This one is buffered bypass. Just to be sure, did you wire it up following the diagram in the doc? It's slightly different for this one. What are your voltages on Q1? Where did you get it? Upvote 0 Downvote
bechbox Member Yesterday at 7:50 PM #4 Robert said: This one is buffered bypass. Just to be sure, did you wire it up following the diagram in the doc? It's slightly different for this one. What are your voltages on Q1? Where did you get it? Click to expand... Yeah, I follow the build doc, so no 3pdt breakout for this build. Can I measure the J113 with a DMM? I don't have a Peak DCA75 or similar Upvote 0 Downvote
