DAJE
- Build Rating
- 5.00 star(s)
I finished this one a couple of days ago but I've been a bit busy.
I have a few footswitch boards donated by @MichaelW and designed by @szukalski so that's what you're seeing here. True to form, I had trouble with the f/s board - the LED refused to work - and tried swapping the LED onto the main board and jumpering the f/s board, which didn't help. So then I reflowed the connection wires between the boards, and the footswitch itself, and that fixed it.
I used a 3 knob type 1 pre-drilled enclosure, and enlarged the original LED hole for the switch and added a new hole for the LED. It's on the opposite side to the way the f/s board is designed, but I did it this way because I have other pedals with the LED in that position. I used a diffuse orange LED with a 5.1K resistor.
The photos really bring out the residue of the IPA I used to clean the far side of the PCB, and also stray dust motes and assorted debris. Oh well.
