flippy69 Member Jan 2, 2022 #1 I would to order a Tayda pre drilled enclosure for the Glory Hole Overdrive but need the "coordinates." This information is included with some of the projects and others not. Does anyone have that information?
TravisM Active member Jan 4, 2022 #2 If no one already has one, I'll print out the sheet and figure out the dimensions for you. Upvote 0 Downvote
Robert Reverse Engineer Jan 4, 2022 #3 Duplicate post, but the coordinates are here: Tayda Drill Template - Glory Hole Upvote 0 Downvote
flippy69 Member Jan 4, 2022 #4 TravisM said: If no one already has one, I'll print out the sheet and figure out the dimensions for you. Click to expand... Thank you very much, it looks like they’ve already been figured out. Upvote 0 Downvote
TravisM Active member Jan 4, 2022 #5 @flippy69 no worries, I got pretty close with a caliper and a printer Attachments Glory_Hole_Drill_MM.JPG 100.3 KB · Views: 5 Upvote 0 Downvote
