Glory Hole - Low buzzing sound
JerryDamm
Last week I finished off building a Glory Hole pedal, everything seems to work fine so far.
Only when it's activated I noticed there i a low sounding buzz/humm, in a sort of pulsating way.
Anyone got a clue what this good be? Broken IC?
Here are some photo's of the build
Thanks in advance
-Jerry
Is there a dust cover on the Tone pot? That could be shorting out on the board. Can we see the other side of the board to inspect soldering? Some of the pot joints look suspect for either too little or being a cold joint.
Try to take voltages from your op amp.
Then it’s down to checking component values and if nothing looks amiss then audio probe the circuit.
This thread is helpful:
Heey Jamie!
I used Polyimide tape to isolate the PCB from the pot on the back side.
Thanks for the thread! Idefinitely will check that out.
I'll try to make a photo later on if the tip from Nostradoomus did not solve the problem.
