Guvernator Build Doc discrepancies?
Stelloh42
Hey all - hoping I can get some clarification on this subject. I built up a Guvernator PCB today and it sounds pretty Marshall-y - just a little underpowered. For comparison - I have built this same board before and remember it having both more gain and more overall volume...
anyway - I was looking at the build doc and comparing the resistor values that are printed on my PCB vs the values on the doc. They don't match up. I went ahead and desoldered the resistors from my current build just to make sure.
unfortunately I do not have the previous build to compare but I will post pics of my build and pics from the pedal PCB website (which correspond to the values on the build doc - I checked)
I guess my question is: which values are right?
thanks!
Thanks - I think I'm going to try both ways (there's only a couple resistor values that differ) and see if there is a difference, or if I'm just imagining my previous build to sound better than it did.
Yep, follow what's on your board.
The circuit hasn't changed, the components are just rearranged a little.
If the build docs are updated to correct an actual error I will generally highlight that value in red in the parts list and make a note.
In most cases the incorrect PCBs are tossed in the trash, but if it's just a single value or two I will mark them out with black marker to indicate that you should consult the build docs.
