I just finished my build of the Nucleus (this is about my 15th pedal or so, about five now from Aion). Never had issues except for this one: I just cannot get it to work, no signal when it's switched on...
- bypass mode works (HW wiring seems OK)
- voltage 9V is ok, LED is on when switched on
- charge pump is working, VA is 17,76V
- triple checked components and soldering joints, all seem OK
- I took some photos of the dissembled pedal
- I took some voltage measurements and put them in the schematics
Hopefully one of you guys can spot a hint what else to check or look for...
Cheers
Cheers
