Smooth clear coat. It’s a really cool finish. G&L ASAT Z3.What kind of finish is that? Is it textured or is there a smooth clear coat?
Yeah I don’t know. I have had this guitar for several years now. I may have to email the folks at G&L and ask for advice.What’s up with the felt washer looking situation? I have no idea how to get that jack out, but I’m very curious now. Let us know when you figure it out.
I've found a reamer super useful for pedal builds too. Especially for various LED bezels where none of my drill bits match exactly the bezel hole size--get close with the drill, then ream to the exact size needed.I guess I need a reamer…
Not sure that’s an option if you’re gonna hammer a reamer into the jack.I’m gonna get a reamer and try delicately unscrewing it. I hope I just need to resolder the lugs and I can just put it back in. I really don’t want to have to replace it if possible.
I need to do the same with my 78 Tele. Fortunately I have a reamer! $10 at home depot.Alright, got a reamer and unscrewed the barrel jack. Here is what I found.
Reference to remember where the two leads from the jack should go:
Weird fuzzy stuff inside the barrel...
And here's my problem: the ground connection looks pretty loose so it's probably been shorting out for a while. I have seen this kind of issue in the past (I fixed two guitars with exactly this same problem a couple months ago) so I was hoping it would be this trivial. But is it the only issue?!?
Replaced wires with fresh (and slightly thicker gauge) ones:
I just wrapped it up and tested and it works like a charm now! No further issues so no need to replace the barrel jack (for now).
Now back to work (like my job, nothing fun).
Samesies!I need to do the same with my 78 Tele. Fortunately I have a reamer! $10 at home depot.
