Nice. I can easily get that from Smallbear. I just got a gift card so I was hoping I could get everything from them but they are out of the BBD.I got the ok from @Robert when I built mine to use an lm358. I have a spare 3207, but need to check to make sure it’s solid
Edit: just tested in my functioning low tide and it appears to be a dud. Sorry to get the hopes up
StompBoxParts has them in stock! Gotta seize this moment!Ugh I also still need a B2M pot for another build that’s impossible to find!
stompboxparts.com
Oh perfect. I forgot to check SBP for the 3207. Thanks!B2M here![]()
16mm Potentiometer - Short PCB Leg
Top Quality Parts for Guitar Effects Pedals and DIY Music Devices. Knobs, Pots, Switches, Kits, LEDs, Enclosures, Jacks, Wire, Resistors, Capacitors, Semiconductorsstompboxparts.com
V3207 here![]()
That's a lot of their stuffView attachment 39464
Uh that’s an interesting policy…
Cool that they have the M65831AP now. A little pricy at $8 a pop, but seems worth it if you’re building their Elysium board instead of dropping $5 for a likely OOS/Counterfeit chip on eBay/AliExpressAionFX has recently expanded its components-vending to include chips such as the Cool Audio V3207D.
Thank you for the offer! those are easier to source than I anticipated so I’ll be ok!So I have the V3207D. I’m not sure if I have the LM258P. I have to look but it’s pretty late where I’m at right now. If you don’t pull the trigger tonight I can give you a definite answer in the am. As for the V3207D I just got a few in for the low tide as well and don’t mind sending you one.
Edit: I should have a LM358 seeing as @Diynot confirmed you can use those as a sub.
No problem the offer is always open if anything happens just shoot me message!Thank you for the offer! those are easier to source than I anticipated so I’ll be ok!
Yes we do, and no minimum order... on anything, ever.@Cabintech should have the 3207
