Help with Constrictor Opto orientation and gain break out pot.
ac30irons
Hi all, first post.
Can anyone help with which way the Optoisolator goes on ? I have attached a pic of how I think it goes (the long leg is top left of the Opto) which would suggest it’s the anode yet I’m sure I can see a little + on the other side (bottom left short leg.)
I would also be really keen to know how you can break out the gain trim so it’s on a pot !
Thanks in advance
Hi all, first post.
Thanks in advance
Please see pic.
The way mine turned out was with the vactrol label underneath, if that makes sense. Try to ensure that the long leg matches the + sign. If in doubt, socket it so you can change as necessary.
Give me a couple of minutes to confirm the trimmer to pot wiring.
