SOLVED Help with my ugly Greengage build
mjh36
Hey this one I need help with. Greengage, my 2nd build. I didn't wanna paint or drill when I ordered the enclosure, so I ordered the closest one I could, then make the pots/switch fit with hookup wire to the holes. I now realize its easy to drill and not ruin the paint.
I tried it outside and inside the box, making sure wires weren't touching. It turns on, lights up, the knobs function, switch functions, but the sound is all scrambled every setting. It does react when I strum, but like a bad Bit Crusher or Korg Miku pedal. Also at one point i noticed that only one of the two red LEDs was lighting up. Very frankenstein looking build i know, thought this would work.
Anyways, I haven't started troubleshooting yet because i only know the basic concepts. But today I will:
I will try to measure all values that i can. Resistance, caps, what else?
I will try to check continuity. Black probe to a ground point, and red probe touching around for beeps, right? Is this the same as a simple audio probe I hear about?
Thanks y'all
20200915_142207.jpg 20200915_142410.jpg 20200915_142832.jpg 20200915_142911.jpg 20200915_142853.jpg Screenshot_20200915-145409_DuckDuckGo.jpg Screenshot_20200915-145447_Office.jpg
an audio probe is a different tool that lets you touch a point on your circuit board when it has audio input so you can hear if the audio is reaching that part of the circuit like it is supposed to. here are some links to articles about building them and using them:
It was IC! I put a TL072 instead of TL1044! Duh haha
Like my first pedal the other day, i turned it on last night... nothing. But i simply didn't put the IC's in the sockets out of excitement. However, this time I put 3 TL072's in, when i needed one TL1044 in there! Now it works great as far as I can tell.
