I want to pair the Mach 1 with the Cleaver in one enclosure. They should fit fine side by side in a 1590BB.
I already have a Mach 1 and I prefer to run it at 18V. However the Cleaver uses a charge pump to convert 9V to 18V internally. So you see the dilemma. If both pedals share one power input in parallel, then supplying 18V would accomplish what I want with the Mach 1, but would overload the Cleaver.
As a solution, can I power the Mach 1 in parallel with the 18V rail of the Cleaver's charge pump? Only the Cleaver would be connected to the pedal's power jack. To power the Mach 1 I would simply run a wire from the Cleaver's 18V rail (D102 cathode on the Cleaver maybe?) to the Mach 1's power input.
This way, I could power the pedal with 9V, but both would be running internally at 18V.
Would this work okay? any modifications needed to run the pedals this way?
