tdukes Active member Apr 4, 2019 #1 It looks like several hot air rework stations are available from Amazon for less than $100. Has anyone here had good or bad experiences with any of these. I am thinking of getting one.
JetFixxxer Well-known member Apr 4, 2019 #3 I have had both. The first one I purchased and didn't work. The replacement was better, but still doesn't heat up without a good smack.
Robert Reverse Engineer Apr 4, 2019 #4 I have this one: https://www.amazon.com/F2C-858D-Soldering-Stations-Accessories/dp/B01NCB4SQ7 It works fine but I really don't use it all that often unless I need to remove an SMD IC.... It's mostly a heat-shrink tool these days.
JetFixxxer Well-known member Apr 4, 2019 #5 Robert said: I have this one: https://www.amazon.com/F2C-858D-Soldering-Stations-Accessories/dp/B01NCB4SQ7 It works fine but I really don't use it all that often unless I need to remove an SMD IC.... It's mostly a heat-shrink tool these days. Click to expand... I got the 69.99 one, but it wasn't 59.99 it was 39.99 at the time.
