droneshotfpv
I would LOVE to build something similar to the Hotone Patch Kommander. I have 2 of them right now, one has 2 of the loops grounded somewhere and causing a low volume when one patch is selected, and also won't work with the 4th patch unless 3 is enabled.
Another SIMILAR item is the "One Control Chamaleo Tail Loop MKII" or the various other One Control items. Just for.more reference.
This issue brought me to the idea of having something to build that is similar, if possible? I could even donate the one that needs work as a donor for tracing if need be / is possible.
It has 4 patches selections, a memory bank (4 banks to store effects orders) , a tuner connection, in, out, and an AMP A/B selector.
I love this thing because you put 4 effects in the 4 loops (you can of course daisy chain effects together, but lets stick with simplicity for now haha), and with a push button selection, turn any or all patches on. I like it because with the 4 selector buttons, I can have effect 1 and 3 on, then select patch 2, and have effects 2, 3, and 4 on, etc etc, and change between them at will WITHOUT having to program it like the BOSS variants. it uses relay switching, and seems like out of all of them, would be the easiest "patch switcher" of it's type to build.
Upvote
6
