farwest1
One of the through-board pads on a pcb I’m working on accidentally filled with solder, with no component in it. Now I can’t get the solder out.
I’ve tried to clean the solder out of it with both a desoldering braid and pump, but I just can’t get a clean hole to reappear. I’ve also tried re-heating the solder and forcing a wire end through, but can’t.
any additional ideas? Can I use a very small drill bit to re-drill the hole? Force an awl or needle through it? Are there other techniques?
