Nostradoomus: yes, it is a Tayda Copper Hammer Tone box. I was fortunate to get some before K Pedals bought them all
Jubal81: Marc Ahlfs describes the differences in detail on the Skreddy website. Here are my impressions...
The Lunar Module (AKA Aldrin) is the hottest of the three and my least favorite. Thru my rig, in a small room, the distortion is too harsh for my liking. It was the first of the three that Mr. Ahlfs designed. His intention was to recreate David Gilmour's guitar tones on DSOtM, hence the name "Lunar Module." It's an all silicon design. Plenty of gain & brightness. Next came the Screw Driver. It is much smoother and my personal favorite. It's the first of the three that I built, which may well be a factor in why I like that one the best. Marc retuned & renamed the BODY (SHARPNESS) & BRITE (BRIGHTNESS) controls, reduced the gain in the first stage replaced the 1st stage silicon BJT with a MOSFET and the last transistor in the chain was changed to germanium. All of the controls are useful over their entire range. With FUZZ and SHARPNESS set to zero and BRIGHTNESS dimed, it's a (mostly clean) Treble Boost. Set everything to noon and you have a bluesy amp-like overdrive. Last out of the chute was the Hybrid Fuzz Driver. It's kind of a mash-up of the LM and SD. According to Mr. Ahlfs, the HFD is optimized for humbuckers. The 1st stage went back to being a silicon BJT like the LM, but the Pre-gain is tuned to act like a Mid Boost instead of an everything boost like it is on the other two pedals. Three of the low-pass filter caps were deleted in the interest of "clarity." The bias was changed in the FF stages and the gain was reduced. The HFD is probably the most amp-like of the three. The distortion can be varied from almost clean to bluesy. No metal sounds in there.
I reacquainted myself with Bill's Law again last night. I wasn't satisfied that my pedal sounded
close to the Skreddy HFD, they should be nearly identical (within the limits of component tolerance and transistor variation). I reviewed my parts list and board... Lo & Behold! I had installed the wrong value input resistor (R2). I had put in the 56K that the Aldrin board calls out on the silk screen instead of the 10K resistor used in the HFD. I switched that resistor out and Viola! Now they sound the same. Only difference is that the TIGHTNESS pot is wired backwards compared to the Skreddy HFD. That's because on the LM, clockwise rotation increases bass, but on the HFD and SD, clockwise rotation reduces bass. Easily fixed, but it's not that big of a deal.
