Would a 100% wet signal mod be possible by clipping lug 1 of the mix pot? I think this would allow full dry and wet signals at CCW, and as you turn the mix pot to full CW, you would decrease the dry signal to the point of only the wet signal. If this is possible you could use a DP3T ON-ON-ON switch with 100% dry - Stock - 100% wet. This would be nice for the times you want to cut out the dry signal completely.
