I built a GE-7 clone based on this schematic, but the volume isn't unity at 50% of volume pot, it's near unity (not quite) at 100% volume pot?
Are you cutting a lot of frequencies?
Did you use 10k pots?
ELPCB, breadboard, or your own PCB?
You could add some gain to the last opamp stage if you wanted too...
I’ve left all frequencies at midpoint (they’re slide pots, all B10K). A GE-7 is meant to boost or cut the level from the center on the level pot, so I’m confused by this one is cutting the signal in half at center. This is my own PCB. I’m hoping to not modify the schematic but instead try fix what is wrong with my PCB of this schematic
Can you post your schematic as well?
BTW where did that enclosure outline come from? I haven't seen that one before.
Good point, my trace can be found in this Drive folder
Enclosures are actually ported over from this Eagle library, it has 3D models included too
It’s worth slightly correcting them because some are 1-2mm off center, but no biggie, I find them very helpful to confirm the build is going to fit.
What’s fun about them is that I can export the GLTF straight into Blender and make renders of them to use if I ever get around to setting up a shop. For instance this render had the PCB and all components included inside the enclosure 😂
I don't know if this is helpful
Are you seeing stable voltages at your opamps? I don't see any decoupling caps any of the opamps (except the NE5532) and your traces are suspiciously thin, especially for the power rail.
The bottom 33KΩ resistor near the top appears to be grounded on both ends, if this is R31 or R33 in the schematic you linked, your 1/2VCC bias rail isn't going to work properly.
Y
Youre right, that 33K isn’t connected, good eye.
Also with the rails, totally fair enough, I plan to beef these up for the next version once I fix this one. I SUCK at layout so the decoupling caps are there if they’re there in the schematic, but probably not placed in a logical place. I think I may have used thin traces because I kept creating islands everywhere that lifted components off the ground pour
just looking again, I just be that 33K that’s the problem, I don’t know what I did there to mess that up so bad
I see red spokes on the left ends of both of those 33K resistors.
The right end of the top 33K goes to VCC, the right end of the bottom 33K has blue spokes which appears to be your ground plane.
It looks like you have a VREF plane (red) rather than individual traces.
That’s correct, I’m away from my computer but I recall one plane is meant to be VREF, is this voltage divider even going to work with the way that 33K is connected to both planes? It almost looks like something that is technically correct to the KiCad but not actually dividing the voltage correctly
