I think I've managed to kill an FV-1 before getting any sound out of it!
I ordered a Deflector board with a pre-soldered chip and populated it in the normal manner EXCEPT I used an SMD 3.3v regulator on an adaptor board. I checked orientation on the datasheet but missed the critical note that orientation shown for the through hole part was from underneath the component whereas the orientation for the SMD related to a view from above. In short, Vin and Vout were reversed which has probably put close to 9v through it.
After finding the problem with the regulator I noted a dead short between the 3.3v rail and ground. I eventually traced this to a short between pin 8 and 11 on the FV-1. I presume this means a dead chip. Anyone think otherwise? Anyone know where I might get a replacement chip in the UK?
Bottom line, don't be stupid like me.
