A bit of a weird issue here... First of all, the pedal works totally fine under normal circumstances! When the power plug is slightly wiggled around in the power jack, the pedal intermittently turns off (sometimes in rare cases it "latches" off permanently - then I have to wiggle the power plug until it turns on again). Mostly curious if anyone else has had this issue with their informant overdrive, or could try wiggling their power plug around and report back?
I thought it was a mechanical issue with the power jack, so I swapped out the jack (different brand jack even) and the issue persisted. Tried powering with different 9V supplies, and even tried wiggling the power plugs in other pedals of mine, but only the informant overdrive flickers off. Granted, I don't have any other pedals that use an internal charge pump.
I built my informant overdrive with an LT1054 charge pump (didn't bridge the jumper on the back, also replaced the LT1054 with no change to the issue), resoldered all the power connections, replaced the pedal's LED, and even upped the 100uF power filter cap to 220uF. No change, still flickers on/off when I gently push down on the power plug in the socket.
Now, you might be thinking that this is not really a problem, but my friend who I built this pedal for plays a lot of gigs and if his board gets moved around by his foot on stage and the pedal begins flickering on/off, it is really awful over a PA system lol
Any assistance or insight would be much appreciated!
