yes it is.Putting a Tayda order together for a TS10 inspired circuit which lists B20k for the Tone pot. Currently Tayda is out of B20 but has B25k. Is that close enough?
Thanks, they were out of those yesterday also. At least the type I was hoping to buy.I think some Tubescreamer variants also use a W20k, you could use that instead
Thanks.yes it is.
do it.
Not much but I can send you one of those as well.While I'm at it, how important is a JRC4559 vs a JRC4558 in a Tim circuit? Any at all?
Thank you! I will DM you.Not much but I can send you one of those as well.
I feel your pain, I also had a lot of out of stocks on pots from Tayda. I usually use alpha, but a few I was able to settle for the Tayda version and they worked fine. I also just built an XC Phase which calls for a C500k pot and I accidentally ordered lug ones instead of PCB leg ones. I just wired the whole thing up with the same wire I use for any other offboard components and it worked like a charm. Took about 2 minutes of extra work and I saved money on buying more pots + paying shipping again. So there's an option for ya since lug ones tend to stay in stock longer than PCB ones.Putting a Tayda order together for a TS10 inspired circuit which lists B20k for the Tone pot. Currently Tayda is out of B20 but has B25k. Is that close enough?
ive made the 'error' of purchasing tayda brand pots so many times that ive learned that it really doesn't matter. at all.Yes, now that I’m thinking about it, I was being picky and wanting the Alpha brand with the PCB pins. And that’s because early on I heard they were good pots so I didn‘t want to risk using a lower quality part. It’s possible I could have gotten on with lugs, or the tayda one. It’s the same thing with box capacitors. I heard that the red WIMA brand were good quality at some point so I’ve tried to stick with them, but it isn’t always possible.
