Finally, some photos! As you can see, I had to take a good amount of wood out of the guitar and have a swimming pool route now. How do you like my battery pack?
Also, you can get coin battery holders for cheap and crazy-hot-glue 'm onto the pickguard... Heck, might even be able to use ones that will load 'm in from the front without having to take the pickguard off.
I think this is the first time I've seen a guitar with a Le Creuset sticker on it. Pretty cool project! Is one of the switches used to connect/disconnect the batteries from the Electra? Or did you use the old stereo jack trick?
The mini toggle is a bypass; power comes on when you plug in. Stereo jack, precisely!
@Feral Feline good eye, that is in fact a Derek Trucks SG on loan from a friend. I couldn't find any three coin cell holders... Have you come across any?
I have one and it would take a jump off an amp-stack or severe stage-diving to dislodge the battery from within if you orient it correctly on the pickguard;
the prongs stick out the bottom make for easy wiring three of them together. Will be more low-profile than any 3-cell stackers you may find.
I'm using 6 coin cells to get a bigger power bank, so to speak. If I could find two "3-pack" holders that would work too, but 6 singles is too much. I looked for rechargeable batteries, but it's hard to find a nice flat one. Eventually, when I have some money to spend and the desire, I'll route a shallow hole in the back for a Fishman battery pack
