dawson
This is a build of the JMK Paralyzer PCB, which splits your signal into two separate loops that are then blended back together via. the knob before mono output.
It's a great little utility circuit!
I've been using an older JMK Paralyzer build in a particular song to gradually switch between a choppy tremolo and a slow, sweeping phasor- turning the massive knob with my foot. It's been working great so far- here's a link to the build report if you're curious: JMK Paralyzer for my SCHMORG
Anyhow, since I've been getting so much value out of my first Paralyzer, I decided it'd be worth upgrading it by adding a true bypass switch that arranges the two parallel loops in series. I tried and tried to think of a way to do this using a smaller switch, but if there is indeed a solution, I didn't find it. I had to go 6PDT, which means I spent $18 on that super awesome switch.. totally worth it!
Here it is:
Now I can run phasor into tremolo!
*I also feel much safer working the knob with my foot now that there's true-bypass.If when I eventually demolish the potentiometer in the middle of a live set, I'll just flip the switch and finish-up in series, rather than being hard-wired through a busted circuit.
That 3d-printed bracket anchors the PCB/POT assembly to the switch so that they don't spin around in there if the nut comes loose.
*I posted the glamor shot first to hide the fact that my etch is way off-center
If you're wondering WTF is wrong with this guy who thinks it's okay to build upside-down pedals with no pants on, this thread may answer a question or two:
SCHMORG
Thanks for reading!
Here it is:
SCHMORG
Thanks for reading!
