MichaelW
- Build Rating
- 5.00 star(s)
This is one of those few pedals that I've built that has not lived up my expectations.
I've generally liked all the LPD pedal line up that I've heard and this one is supposed to represent his favorite 68 Plexi.
I really wasn't expecting it to sound EXACTLY like a Plexi, but I dunno, it's not anything like one, nor his description on the website
"I wanted something that sounded and felt like my favorite 1968 Plexi. Completely natural note decay, no strange fizzy artifacts. It’s very dynamic, and responds to the guitar volume control and pick dynamics very well. Highly versatile with super-low noise and killer sustain, without needing a ton of distortion or fuzz to get it. "
That blurb is what got me excited about building this when it dropped. Then I kinda forgot about it, and when I looked at the board in my pile of PCB's somehow I conflated it with a BSIAB that I'm also working on. (I've been doing a lot of conflating lately it seems....)
It wasn't until @szukalski's build report that I remembered it wasn't an "Eddie-in-a-box" pedal I got excited about it again. I drilled and painted an enclosure and have been waiting for it to try for about a week now (more one that later).
It's not a bad sounding pedal but it's also not knocking my socks off either. I put it side by side with all the MIAB pedals I've built so far....
Golden Falk
XS Drive
King Midas
To me the Golden Falk still rules, it's the most amp-like and most flexible in terms of available tones. You can get from plexi-ish to JCM800-ish between playing the the two gains and the toggle.
The Jump drive by comparison sounds like a YATS. It's got a pronounced mid hump and is somewhat muffled. The overdrive itself is pretty smooth but a bit of a one trick pony and it's a bit hard to find that pony. Definitely has that nasally pedal sound as opposed to the bigger more open sounding Falk.
The XS drive has that same "pedal-ish" quality but it's got a lot more tones available and flexibility to it. I can get an early "Custard Pie" or a later JCM sound out of the XS with all it's toggles.
Tomorrow's agenda is to try some different guitars and amp models with it to see if I can crack the code
So, the enclosure, I really like this "Hammered Black" Krylon color but I think I need to try some different brands or series from Krylon. This thing just won't cure.
It's been sitting for a week drying and I still got fingerprints all over it from how soft the finish is. That's two pedals I've painted with this paint with the same result.
I really tried to go slow, put down a coat of primer then hit it with multiple very thin coats of color over a couple of days. It LOOKED nice before I started handling it.
I love the idea of being able to do rattle cans and have access to more colors than Tayda's powdercoat but at $10 a can, it's getting to be a bit of a discouraging endeavour trying different colors.
No substitutions on this build. I built off the PCB as there's no BOM or schematic I could find. I used a pair of Russian G223 Ge Diodes that measured ~350-ish on my GM328 tester (which I've found out tests diodes at 10ma).
The toggle switch, as far as I can tell from the board traces do not control the diodes, seems like those are always on. But rather I "think" it toggles the second BJT transistor. So it's either running a single 2N7000 or both depending on the toggle position.
Used my @swelchy printed pot covers
Looking at the pictures it looks like I didn't do a great job cleaning the board off after cleaning the flux off. I've been using the MG Chemicals Flux remover then rinsing with a little QD contact cleaner. I think I wiped the back of the board off after that with a cotton cloth but left some "Schmook" on the front.....hahah.
Built itself went super smooth and a typically thoughtfully laid out @Robert board. Next up in my MIAB series is a long waiting BSIAB2 that's been on the back burner for over a month now....
Golden Falk
XS Drive
King Midas
