Thanks man took me All Day yesterday took a page out of @fig book once I saw him do the point to point soldering I had to try something similar I might go all the way with point to point on one build.Wow, nice wiring. Beautiful inside and out.
Looks great! What wire size do you use for P2P? I imagine you can buy it bare right? I’d be interested to give it a try
Thanks so much I want to go even further and do a whole pedal point to point!
Point to point using some sort of turret board?
I once made a Bazz Fuss by soldering the components directly to each other while using (thick solid core) wire that held everything in place to connect to jacks and stuff. That wasn't on your level of bending execution though ...
You can also fold it back on itself ie 4 feet becomes 2 feet long.Wire - Bus, 100 foot Spool, tinned copper | Amplified Parts
Solid tinned copper bus wire. 105°C temperature rating, 600V.www.amplifiedparts.com
I bought 22 gauged wire and used a drill to straighten it out and cut to your desired length!
That might be my solution to thick gauge wire instead of buying a whole new spoolYou can also fold it back on itself ie 4 feet becomes 2 feet long.
Clamp in the vice & the folded end in the Drill Chuck & hold tight & slowly turn drill on & stop at desired twist.
Effing GENIUSYou can also fold it back on itself ie 4 feet becomes 2 feet long.
With a couple of runs you will get a feel for it.
I learned to do it when working on Sprintcars where Captured bolts were required to be drilled through the head of the bolt & tied with Stainless steel wire to prevent bolt loosening & falling out!That might be my solution to thick gauge wire instead of buying a whole new spool![]()
You learn something new everyday on this forum!I learned to do it when working on Sprintcars where Captured bolts were required to be drilled through the head of the bolt & tied with Stainless steel wire to prevent bolt loosening & falling out!
It looks way neater than a single strand Ha Ha!
