Kliche mini diode pads shorted to gnd.
Ismacdon
I'm not sure if the pcb is bad or the switch but all 4 diode pads are shorted to gnd. I'm going to replace the switch tonight, thought maybe someone else has seen this. I bought a few of these boards and the rest are solid.
Take a close look at the switch wiring pads, if that doesn't help I can send you a diagram of the top/bottom traces.
That particular net snakes around the board a little.
A manufacturing defect isn't impossible, but I'd rule out everything else first.
