griff10672
Regarding the Kliche mini ...
Anyone have an idea why I would have voltage on my output jack ........ I'm getting 0.513 V AC / 0.5 mV DC on my out put jack ...
and throughout the buffered bypass circuit . If I pull the TC1044SCPA out ..... the Voltage goes away ..... it seems to be only on the buffer path of the circuit ...
when I trace the circuit on my scope .... from input to output .... nothing on my input jack ... or R31 .... the voltage shows up right on the side of R1 that touches C1 and runs through the whole buffered bypass part of the circuit to my out jack .
I'm assuming that's what's destroying my bypassed tone and causing some weird buzzing on the end of played notes / chords
When I trace my Kliche OD none of this happens .... zero voltage ... bypassed my signal is fine if not sounding better due to the buffer working correctly I'm assuming .
literally the only difference in the two are that I didn't use a Footswitch board on my Kliche OD .... I wired the footswitch direct to the main board .
all the parts are the same ........
