ddavis20341
I have a Kliche build that has been giving me some problems recently. It stopped working - passing either bypass or circuit audio - and the only sound is just a rhythmic pumping noise (it pumps in time with the LED on the power brick in the video below). I tried swapping the charge pump and DC jack, re-flowing joints, etc. and still no dice. As you can see, voltage jumps rhythmically, but is always between 0-0.5V. I checked continuity on ground between DC jack, input output jacks, etc. Could it be a bad filter cap? Confused as to what to try next.
