LFO LED on the Abyss and Photon Vibe
Dice1012
Going to build a Photon Vibe and The Abyss. Does the LED status light blink in time with the LFO or is this there a mod that can be added to do this. If anyone knows it would be appreciated. Thanks
You could try wiring an indicator LED across D2. It'll affect the current draw of the LFO, but I don't know if it'll be enough to cause any issues... You'd just have to try it and see how it works.
Just ignore the SW and GND pads on the PCB and use two lugs of the switch to open the circuit for the new indicator LED.
I may just try it in conjunction with the status LED. Thanks
