LM317 question
Oh_Discordia!
Working on a compressor pedal that calls for an LM317 and it indicates a TO220 package (the board has room for it). I ordered a few LM317's that are TO92.
Ok to use?
Here is the doc:
GCI Compressor
The rule of thumb is under 200mW -> no heatsink req'd
The load current is all flowing thru the programming resistors (R14 & R15).
Iload = (Vo - Vadj) / R15 = 1.25V / 150Ω = 8.33mA
Pdiss = (Vin - Vout) * Iload = 4.5V * 8.33mA = 37.5mW
You're good to go.
BTW, that compressor is the same as the Engineer's Thumb except for one extra knob. That extra knob is unnecessary because VOLUME & GAIN do the same thing. Don't set THRESHOLD below noon or you'll get distortion.
You're good to go.
Thanks for the calculations Chuck! Hoping to wrap it up tonight - I'll keep the threshold tip in mind.
