EDIT - So I just realized that my drawing is not 100% accurate and misleading - for the right footswitch, you'll need to rotate the footswitch 90 degrees! The lugs will have to be vertical, not horizontal, for it to work as shown. My bad!
Other than that it's correct. With the lugs oriented vertically, it goes:
(Red LED Cathode) (CLR to Ground) (Green LED Cathode)
(PCB1 Input) (Main Input) (PCB2 Input)
(PCB1 Output) (Main Output) (PCB2 Output)
So the Loft Fuzz is based on the EQD Spires, and the way the Spires works, it has a master on/off footswitch, and the other footswitch flips between two fuzz circuits.
Now if it were me (and I just ordered the boards, so I guess it will be lol), and I were putting these two circuits in one box, I'd wire them up independently with their own on/off switches (and then you can even stack them!), but if you want to recreate the functionality of the EQD Spires, I'm pretty sure this wiring diagram would do it (with a two-color common-anode LED, for common-cathode you'd flip 9V and ground)
