Has anyone whipped up a simple looper for Terrarium? I think I recall seeing one for the funbox PCB, but if there was already a looper specific to Terrarium anyone could share I'd be thankful
This is one I wrote for Terrarium, it has abunch of other effects in there but you could strip those out if you just wanted a looper. Press the footswitch once to record, once to stop recording and start playback, and repeat for overdubbing. Double tap to pause playback, double tap again to resume. Hold to erase the loop. It will slowly pulse the LED while recording, solid LED while in playback, and blinking LED while paused. It also uses one of the toggle switches to put the loop into reverse or forward. I think I put something crazy like 5 minutes of max loop time, since I'm not using the SDRAM for anything else.
