SillyOctpuss
So I have about 30 very low gain J201s. Is there anything I could realistically use these for or should I consign them to the trash?
Yeah! Inquiring minds want to know!What do you mean by "low gain" J201?
That's basically how I think of them tbh. Any circuit I've tried them in has sounded pants and has had virtually no gain/drive e.g. a plexi drive etc I don't know if they're fake or just out of spec partsWhat do you mean by "low gain" J201?
I did measure them using the improved jfet matcher on tagboard effects ages ago and from memory they were technically in spec but only just. I'll pop a few onto the transistor tester shortly and let you know.Measure Vp and Idss of one or two transistors and we'll find out if those are fakes. Report results here. Where did you buy the transistors?
A closer look at the Fetzer Valve
www.runoffgroove.com
I second what CDB said - could be incorrect biasing.
Yes I have done it before a long time ago and they checked out as being in spec but literally only just. I don't think they're fake to be honest but I do think they're rejects which have been resold. I bought them shortly after I started building pedals in 2015ish when I didn't know any better.There's something odd with your readings. What is VG? Can you breadboard a circuit from Runoffgroove website?
Either way I don't think the j201s I have are going to be useful for anything I'd actually like to use them forFrom my experience with J201 - for Vp, readings between 0.6 and 0.9V are ok. As for the Idss - 0.5 to 0.7mA.
